Use this procedure to modify the assigned name for the Service Identifier (I-SID).
- Select ISID.
- Select Global Name.
- Double-click the name of the I-SID in the ISID Name field, and then type a new name.
- Select Apply.
Global Name Field Descriptions
Use the data in the following table to use the Global Name tab.
| Name | Description |
| ISID Id | Specifies the index number that uniquely identifies the I-SID. |
| ISID Name | Specifies the name of the I-SID, which can be up to 64 characters. |
| UsedByType | Specifies the I-SIDs that are in use as services. An I-SID can have one base type or a combination of base types so that multiple services can use the same I-SID at the same time. |
